13 years agolibrary ieee;
use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity onehot_binary is port ( onehot_in : in std_logic_vector; binary_out : out std_logic_vector ); begin assert 2**binary_out'length = onehot_in'length severity failure; end; architecture rtl of onehot_binary is function one_hot_to_binary ( One_Hot : std_logic_vector ; size : natural ) return std_logic_vector is variable Bin_Vec_Var : std_logic_vector(size-1 downto 0); begin Bin_Vec_Var := (others => '0'); for I in One_Hot'range loop if One_Hot(I) = '1' then Bin_Vec_Var := Bin_Vec_Var or std_logic_vector(to_unsigned(I,size)); end if; end loop; return Bin_Vec_Var; end function; begin binary_out <= one_hot_to_binary(onehot_in, binary_out'length); end;
