EDing's avatar
EDing
7 years ago
10AS027E3F29I2SG simulation error
# Time: 0 ps Iteration: 0 Instance: /bsm_epl_pcl_egl_bsf_tst/uut/b2v_inst File: /build/swbuild/SJ/nightly/18.0std/614/l64/work/modelsim/eda/sim_lib/altera_mf.v
# ** Error: (vsim-3935) ../../BSM_EPL_PCL_EGL.vhd(1316): Port 'A_OUT' not found in the connected module.
# ** Error: (vsim-3935) ../../BSM_EPL_PCL_EGL.vhd(1316): Port 'A_IN' not found in the connected module.
  • Hi Ellen, I have taken a look at the design, please add the following lines to you “BSM_EPL_PCL_EGL.vhd” file --edits for simulation library altera_mf; use altera_mf.all; library altera; use altera.all; Let me know if you are able to proceed with this. Thanks, Regards, Arslan
  • EDing's avatar
    EDing
    Thumbs up to you again, Arslan!​
  • EDing's avatar
    EDing
    What's missing here to set up the simulation with Qsys IP? Thanks!​
  • EDing's avatar
    EDing
    Hi Arslan,
    Glad to see your answer here! Thanks! Attached is the log file, could you tell what's missing from the log please?
    Best,
    Ellen
  • Hi Ellen,
    I am looking at the log file, it is hard to pin point the exact issue. As I can see a couple of IP's been compiled in the design.
    Is it possible to share the design in a private message may be to take a further look ?
    Or you can point me what IP was instantiated at line number pointed in Error message.
    Also can you confirm if IP is generated in verilog or vhdl ?
    Arslan
  • EDing's avatar
    EDing
    Hi Arslan! I have opened a case 00398071, it would be great if you can help identify the problem. Thanks!​
