EDing
7 years ago10AS027E3F29I2SG simulation error
# Time: 0 ps Iteration: 0 Instance: /bsm_epl_pcl_egl_bsf_tst/uut/b2v_inst File: /build/swbuild/SJ/nightly/18.0std/614/l64/work/modelsim/eda/sim_lib/altera_mf.v # ** Error: (vsim-3935) ../../BSM_EP...
MuhammadAr_U_Intel
Contributor
7 years agoHi Ellen,
I am looking at the log file, it is hard to pin point the exact issue. As I can see a couple of IP's been compiled in the design.
Is it possible to share the design in a private message may be to take a further look ?
Or you can point me what IP was instantiated at line number pointed in Error message.
* Error: (vsim-3935) ../../BSM_EPL_PCL_EGL.vhd(1316): Port 'A_OUT' not found in the connected module.
Also can you confirm if IP is generated in verilog or vhdl ?
Arslan
