15 years ago
10.1_quartus_linux.sh on Fedora 14
Any one can help about setup log as below?
free web edition installation on Fedora 14
altera_setup.log
Traceback (most recent call last):
File "<string>", line 23, in <module>
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 436, in importHook
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 521, in doimport
File "/acds_builds/SJ/nightly/10.1/153/l32/work/installer/linux32/build/pyi.linux2/altera_installer_cmd/outPYZ
1.pyz/cli", line 23, in <module>
1.pyz/altera_installer", line 29, in <module>
1.pyz/downloader", line 21, in <module>
1.pyz/hashlib", line 136, in <module>
1.pyz/hashlib", line 63, in __get_builtin_constructor
File "/tools/python/2.6.4/linux32/pyinstaller/iu.py", line 455, in importHook
ImportError: No module named _md5
    [study@psy altera_installer]$ ./setup
    Welcome to Altera Software Installer
    Copyright (c) Altera Corporation 2010
    Starting GUI. If nothing shows up, or you don't have an X display, run:
    ./setup --help
    for commandline usage.
    NOTE: All output has been redirected to /tmp/altera_setup.log
    [study@psy altera_installer]$ ./setup --help
    ./setup: line 61: exec: altera_installer_cmd: not found
    [study@psy altera_installer]$ cat /tmp/altera_setup.log
    ./setup: line 59: exec: altera_installer_cmd: not found
    Do anyone know how to solve it?Thank you !:confused:
    My problem has been resolved!Just need to add a variable that points to the location of "altera_installer_cmd"!
    --- Quote Start ---
    --- Quote End ---
    Can you explain in a bit more details I am facing the same issue.
    I had the same problem on Ubuntu 10.04 LTS.
    After some trying with the bash script, I figured that you directly can call the altera_installer_cmd.
    1) Extract the sh file (in my case to /temp/10.1_modelsim_ase_linux)
    2) Goto
    /tmp/10.1_modelsim_ase_linux/altera_installer
    3) Run
    ./altera_installer_cmd --source=/tmp/10.1_modelsim_ase_linux/altera_installer --standalone --install modelsim_ase &> /tmp/altera_setup.log
    If you're lucky, then the setup GUI appears.
    Hope this helps,
    Jonas
    I get the following error:
    ./10.1_quartus_linux.sh: line 396: altera_installer/bin/altera_installer_gui: Accessing a corrupted shared library
    I get the same issue when calling altera_installer_cmd directly.
    Any ideas?
    does Ubuntu 10.10 have python 2.7 installed by default? i tinkered with F14 and QII 10.1 installer and didn't get very far, i think i narrowed the problem down to python 2.7
    I also having the same problem (Seems that is also not unique to Fedora14 though),
    found this on a Fedora forum but it still doesnt help, seems to be persuing the python aspect
    (I cant paste/post the link) but on the fedora forums I searched for
    ÏmportError:No module named md5&#901;
    forums.fedora.org/archive/index.php/t-254766.html
    and found some people also struggling with the Quartus install isue
