15 years ago.VCD file Generation
I am having a problem generating the .VCD file for power analysis. In my quartus 2 settings,my Desgn instance name is check,now coming modelsim altera, I need to Enable VCD to dump signals under a desired instance using the below syntax. - Syntax: vcd add <path_to_instance>/* How do i find the path to my instance or what does it really implies? Thanks in advance.
