11 years ago --- Quote Start --- thanks your reply/suggestion, I follow / tried, the result is : although it compile and simulate(tb), but no wave form and its message stated: no data(for all variables, clk, rst, din, dout), so plz help again or any other advanced programer's advice. thanks a lot in advance. (according to that book, "circuit design and simulation with VHDL 2nd edition, that example is worked on MentorGraphic's modelsim, not altera's; so if anyone have successful run's altera modelsim program(both design file and its testbench file in vhdl(.vhd) form of short/simple programs, plz point/refer a link or post on this thread. thanks) --- Quote End --- after simulation you will need to add these objects (clk,reset,din,dout) to ayour waveform. then run the waveform.
