15 years ago
.sof file generation issue
Hi
i am working on Quartus II subscription edition v6.0. i have cyclone II device.
I also having license.
But the problem is "when i compiled a design .sof is not generated."
May i get some help regarding this issue?
Why .sof is not generated?
Best
Rizwan
    licence technology needs some number from your system to identify you. This number is then fixed and encrypted in the licence file.
    option1 : C drive serial number. fixes licence to your PC only. if you change drive or pc, it will not work.
    option2: NIC, netwrok IF card serial number: fixes it to your PC.
    option3: software guard. a small piece of hardware with secret number from vendoe and attached to your parallel port or USB. good if you change PC.
    option4: floating licences stored on network servers.
    When you apply for licence, it asks for your ID number. It looks like you were asked about NIC. It should be ok. But I don't understand why the NIC is displayed but not sen by licence.
    --- Quote Start ---
    --- Quote End ---
    yes it is something amazing!
    Further i want to add something more to your knowledge that in assembler compilation report it is displayed in the messages window:
    "unable to generate programming files as Quartus II is working in Evaluation mode"
    Thank you
