9 years ago.sdc for reconfigurable PLL
Hi, Here is my situation: I have created design which contains PLL with dynamic reconfiguration, and dynamic phase shift options. Input clk of PLL can change in range from 5MHz to 200MHz...
9 years ago --- Quote Start --- - Your external device supplies a 5-200 MHz clock. --- Quote End --- Yes --- Quote Start --- - The delay from the external delay may also change. --- Quote End --- Yes --- Quote Start --- - You plan to deal with this by changing the PLL configuration, to have a suitable output frequency and phase. --- Quote End --- Yes --- Quote Start --- An interesting approach. --- Quote End --- Why? Am I trying to solve this problem in some kind of unusual way? :) --- Quote Start --- Q1: Do you have discrete set of frequencies/delays or are you in a situation where anything is possible? --- Quote End --- Frequency can be any from the given range 5-200 MHz and 3 sets of delays (3 different external devices) --- Quote Start --- Q2: Is your entire design running on that single PLL output clock or do you have multiple clocks? --- Quote End --- There are more clocks and other interfaces but data is passed to other clock domain by using dual clock FIFO. Does this make any difference?
