.ip/.qip PLL how to disable sdc generation?
- 3 years ago
Unfortunately, we don't have a notification system in place. However, I can provide you with a ticket ID [15013771573] so that you can submit a new case and get an updates on this enhancement request status from the respective agent. This will allow you to inquire about the status of the request, whether it is planned, implemented, or rejected. I suggest requesting an update after approximately one year or so.
It's worth mentioning that there is a backlog of enhancement requests on the engineering side, and resources are limited. This is the reason for the extended timeframe required.
Richard Tan
If you're trying to use set_clock_groups, can't you just add them to your top-level .sdc file which would override the PLL .sdc?
