.ip/.qip PLL how to disable sdc generation?
- 3 years ago
Unfortunately, we don't have a notification system in place. However, I can provide you with a ticket ID [15013771573] so that you can submit a new case and get an updates on this enhancement request status from the respective agent. This will allow you to inquire about the status of the request, whether it is planned, implemented, or rejected. I suggest requesting an update after approximately one year or so.
It's worth mentioning that there is a backlog of enhancement requests on the engineering side, and resources are limited. This is the reason for the extended timeframe required.
Richard Tan
By default, you can't edit this parameter in the IOPLL IP as it is invisible, but you can do some script changes and make it visible in the GUI when you initialize the IP.
Find altera_iopll_init.tcl file in the <quartus installation directory>\ip\altera\altera_iopll\common, go to line 301 and changes it from:
{gui_skip_sdc_generation BOOLEAN "" "" false true false \
true "" } \
to:
{gui_skip_sdc_generation BOOLEAN "" "" true true false \
true "" } \
After that, open the iopll.ip parameter editor GUI, in your Quartus project navigator, and you can see Parameter tab and an option "gui_skip_sdc_generation" pop up. Click it to enable it.
Richard Tan
- AEsqu3 years ago
Contributor
Thank You for this info Richard but
as Quartus is installed centrally by our IT, I cannot change the option.
Would that be possible to make the option visible by default in a future version of Quartus?
Alex.
