AEsqu's avatar
AEsqu
3 years ago
.ip/.qip PLL how to disable sdc generation?
Hello, When I create a PLL IP via Quartus (22.4 pro), It also creates .sdc constraint for it which clashes with my .sdc constraint (duplicate point, not possible to set as async group ..). I could...
  • RichardT_altera's avatar
    3 years ago
    Unfortunately, we don't have a notification system in place. However, I can provide you with a ticket ID [15013771573] so that you can submit a new case and get an updates on this enhancement request status from the respective agent. This will allow you to inquire about the status of the request, whether it is planned, implemented, or rejected. I suggest requesting an update after approximately one year or so.
    It's worth mentioning that there is a backlog of enhancement requests on the engineering side, and resources are limited. This is the reason for the extended timeframe required.
    Richard Tan
