14 years ago# Invalid time string specified: in ModelSim
I'm using ModelSim Altera Starter Edition 6.6 for simulating some very simple designs. I started a new project, compiled and everything was ok. But when I had wanted to start simulation, I have opene...
14 years agoMy code is the following:
entity ex_or is
port(a,b,c,d : in bit;
x,y,z : out bit);
end ex_or;
architecture a of ex_or is
begin
x <= a xor b;
y <= a xor b xor c xor d;
z <= (a and b) xor (c and d);
end a;
It is just an exercise from a Digital Electronic book, from the chapter of XOR gates. I'm just trying to get used with VHDL. I already simulated an equally simple code to test AND and OR gates and it worked yesterday. But when I try to do it now, I get the same result. I will take a look in this example, it seems useful. Thanks. --- Edit: I just tried the example and got the same thing: Invalid time string specified, grey wave window. It doesn't seem to be something with code, but in some configuration or command.
