** Error: (vsim-3033)
Done simulation. Check the file and image attached. Go to folder simulation -> modelsim -> execute test_run_msim_rtl_vhdl.do in modelsim.
Do make sure IP .sip file are included for compilation.
If still got error, modify the test_run_msim_rtl_vhdl.do like below:
Uncommented (#) this line vcom -93 -work work {Z:/test/pll_modelsim/pllreconfig.vho}
Suppress error (vsim-10000): vsim -suppress 10000 -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cyclonev -L rtl_work -L work -L pllreconfig -L pllreconfig -voptargs="+acc" PLLS_tb
Then execute the modified test_run_msim_rtl_vhdl.do in modelsim.
Sheng
Sorry for the inconvenience, but the solution is not acceptable, since the project would stop being portable, because for the simulation to work I have to modify the .do file so that it correctly routes my folders, do you have any other solution for avoid that problem?
