19 years agozd1211b can not work on uClinux-dist-20060803
Hi, hippo I following your "WiFi" steps to try "GW-US54GZL" Wireless LAN USB Adapter on DE2 , bit it can not work. display following message: />modprobe zd1211b ZD1211B - version 2.15....
19 years ago --- Quote Start --- originally posted by faye@Nov 3 2006, 12:04 PM my friend used notbook to try out lab's ap, it is ok.
so,it is zd1211 drivers have problem.@@
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19126)
--- quote end ---
--- Quote End --- We returned to the origin. Did you use a Linux PC to try out the driver? You need to compile and install the modules to your Linux PC, with make. And try out the usb wifi card on your LInux PC.
