19 years agozd1211b can not work on uClinux-dist-20060803
Hi, hippo
I following your "WiFi" steps to try "GW-US54GZL" Wireless LAN USB Adapter on DE2 , bit it can not work. display following message: />modprobe zd1211b ZD1211B - version 2.15.0.0 vendor_id = 0053 product_id = 5301 USB 1.1 Host Release Ver = 4810 EEPROM Ver =4810 Finsih download Firmware. Ready to reboot PA type : 0 AiroHa AL2230S_RF AllowedChannel = 000107ff Region :16 usbcore: registered new driver zd1211b />iconfig eth0 up />iwconfig lo no wireless extensions. Warning: Driver for device eth0 has been compiled with version 20 of Wireless Extension, while this program is using version 17. Some thing may be broken... eth0 ESSID:off/any Nickname:"" NWID:0 Channel:0 Access Point: 23:00:31:00:00:00 Bit Rate:2.35631Mb/s Tx-Power=2356312 dBm Sensitivity:0/0 Retry:on RTS thr= 2356312 B Fragment thr=2356312 B Encryption key:0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000-0000 Power Management on eth1 no wireless extensions. I used NoteBook testing my Lab's wireless LAN it is ok ,but on target board can not receive Access Point. maybe is driver version problem? Please help me!26 Replies
previous post removed.
Warning: Driver for device eth0 has been compiled with version 20 of Wireless Extension, while this program is using version 17. The warning does not matter. - Altera_Forum
You have to do some wireless tools,
iwlist eth0 scanning # find available APs iwconfig eth0 ap auto essid "Your SSID" # connect to an AP If your AP is protected, you need to add key to iwconfig, see `man iwconfig` - Altera_Forum
Hi ,hippo ^^
I have wireless tools. I used iwlist eth0 scanning, but it can not found available APs. What's problem?I don't know. - Altera_Forum
--- Quote Start --- originally posted by faye@Nov 2 2006, 02:49 PM hi ,hippo ^^i have wireless tools.
i used iwlist eth0 scanning, but it can not found available aps.
what's problem?i don't know.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19091)
--- quote end ---
--- Quote End --- Please try the driver on your Linux PC or notebook. I mean, without nios2 patch.
There are isp1362-hcd driver update in the CVS of blackfin uclinux.
I will check if I can merge the update. But it will take some time. - Altera_Forum
I used DE2 Board , it size of SDRAM is 8MB ,download image at address 0x00500000, but it 3MB space can used.
I added zd1211b.o to romfs , than make it, the IMAGE is 3.2MB. It is exceed free memory, display out of data. ~"~ How slove this problem. Please help me. @@ - Altera_Forum
--- Quote Start --- originally posted by faye@Nov 2 2006, 08:42 PM i used de2 board , it size of sdram is 8mb ,download image at address 0x00500000, but it 3mb space can used.i added zd1211b.o to romfs , than make it, the image is 3.2mb.
it is exceed free memory, display out of data. ~"~
how slove this problem.
please help me. @@
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19101)
--- quote end ---
--- Quote End --- Please run "make" and "make linux image" . The "make" will strip the modules, so the compressed image should be around 1.5M .
--- Quote Start --- originally posted by hippo+nov 2 2006, 10:22 am--><div class='quotetop'>quote (hippo @ nov 2 2006, 10:22 am)</div>--- quote start ---
<!--quotebegin-faye@Nov 2 2006, 08:42 PM i used de2 board , it size of sdram is 8mb ,download image at address 0x00500000, but it 3mb space can used.
please help me. @@
--- quote end ---
--- Quote End --- Please run "make" and "make linux image" . The "make" will strip the modules, so the compressed image should be around 1.5M . <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19105)</div> [/b] --- Quote End --- hi, hippo I compile zd1211b modules and copy to romfs , than "make" and "make linux image" the size of zImage is 2.64MB, I download to DE2, but is display out of memory. Is this DE2 memory space to few?
PS: I only copy zd1211b.o to romfs.
--- Quote Start --- originally posted by faye@Nov 3 2006, 10:38 AM ps: i only copy zd1211b.o to romfs.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19120)
--- quote end ---
--- Quote End --- Something wrong in your romfs. cd ~/uClinux-dist rm -rf romfs make romfs make cd ~/zd1211 make # compile modules and copy to romfs, the make file do the copy, don't copy it by hand cd ~/uClinux-dist make # depmod and strip the modules (ie, remove debug symbols and reduce the size) make linux image # to update initramfs
