21 years agoYour hardware and uClinux
Hi again, Adding an Avalon custom hardware and its software driver (either HAL or not) is easy and straightforward. Having said that I mean the standard Nios II IDE project_syslib/system_descri...
21 years agoI guess it depends if you want to build a proper Linux driver for your avalon hardware. The basic IRQ and base address for your hardware should appear within the
<project>/build/include/nios2_system.h file in your kernel project directory. If you're not interested in building a driver, then the hardware can be accessed from a regular Linux application as it would be in a non-HAL standalone application. If you're interested in building a driver, I think there was a thread in this forum to help you get started...
