20 years agox264 for uclinux on DE2
I want to add x264( encoder for h.264) to uclinux as an application. I follow uClinux-dist-test/Documentation/Adding-User-Apps-HOWTO . 1. add a line to user/Makefile , dir_$(CONFIG_USER_X264_X264) +=x264 2. add a line to misc section of config/config.in, bool 'x264' CONFIG_USER_X264_X264 3. mkdir ~/uClinux-dist-test/user/x264 4. put all the code in user/x264 dir, 5. create Makefile in user/hello dir, The Makefile ad follows: # Makefile include config.mak SRCS = common/mc.c common/predict.c common/pixel.c common/macroblock.c common/frame.c common/dct.c common/cpu.c common/cabac.c common/common.c common/mdate.c common/csp.c common/set.c common/quant.c encoder/analyse.c encoder/me.c encoder/ratecontrol.c encoder/set.c encoder/macroblock.c encoder/cabac.c encoder/cavlc.c encoder/encoder.c encoder/eval.c # Visualization sources ifeq ($(VIS),yes) SRCS += common/visualize.c common/display-x11.c endif # MMX/SSE optims ifeq ($(ARCH),X86) SRCS += common/i386/mc-c.c common/i386/dct-c.c common/i386/predict.c ASMSRC = common/i386/dct-a.asm common/i386/cpu-a.asm common/i386/pixel-a.asm common/i386/mc-a.asm common/i386/mc-a2.asm common/i386/predict-a.asm common/i386/pixel-sse2.asm common/i386/quant-a.asm common/i386/deblock-a.asm OBJASM = $(ASMSRC:%.asm=%.o) endif # MMX/SSE optims ifeq ($(ARCH),X86_64) SRCS += common/i386/mc-c.c common/i386/dct-c.c common/i386/predict.c ASMSRC = common/amd64/dct-a.asm common/amd64/cpu-a.asm common/amd64/pixel-a.asm common/amd64/mc-a.asm common/amd64/mc-a2.asm common/amd64/predict-a.asm common/amd64/pixel-sse2.asm common/amd64/quant-a.asm common/amd64/deblock-a.asm OBJASM = $(ASMSRC:%.asm=%.o) ASFLAGS += -Icommon/amd64 endif # AltiVec optims ifeq ($(ARCH),PPC) SRCS += common/ppc/mc.c common/ppc/pixel.c common/ppc/dct.c endif # VIS optims ifeq ($(ARCH),UltraSparc) ASMSRC += common/sparc/pixel.asm OBJASM = $(ASMSRC:%.asm=%.o) endif ifneq ($(HAVE_GETOPT_LONG),1) SRCS += extras/getopt.c CFLAGS += -DHAVE_GETOPT_LONG=0 else CFLAGS += -DHAVE_GETOPT_LONG=1 endif OBJS = $(SRCS:%.c=%.o) DEP = depend .PHONY: default fprofiled clean distclean install uninstall default: $(DEP) x264$(EXE) libx264.a: .depend $(OBJS) $(OBJASM) ar rc libx264.a $(OBJS) $(OBJASM) ranlib libx264.a x264$(EXE): libx264.a x264.o matroska.o $(CC) -o $@ x264.o matroska.o libx264.a $(LDFLAGS) x264vfw.dll: libx264.a $(wildcard vfw/*.c vfw/*.h) make -C vfw/build/cygwin checkasm: tools/checkasm.o libx264.a $(CC) -o $@ $< libx264.a $(LDFLAGS) common/amd64/*.o: common/amd64/amd64inc.asm %.o: %.asm $(AS) $(ASFLAGS) -o $@ $< .depend: config.mak rm -f .depend# Hacky - because gcc 2.9x doesn't have -MT $(foreach SRC, $(SRCS) x264.c matroska.c, ( echo -n "`dirname $(SRC)`/" && $(CC) $(CFLAGS) $(SRC) -MM -g0 ) 1>> .depend;) config.mak: $(wildcard .svn/entries */.svn/entries */*/.svn/entries) ./configure $(CONFIGURE_ARGS) depend: .depend ifneq ($(wildcard .depend),) include .depend endif SRC2 = $(SRCS) x264.c matroska.c# These should cover most of the important codepaths OPT0 = --crf 30 -b1 -m1 -r1 --me dia --no-cabac OPT1 = --crf 18 -b2 -m3 -r3 --me hex -8 --cqm jvt --direct spatial OPT2 = --crf 24 -b3 -m6 -r6 --me umh -8 -w -t1 -A all --b-pyramid --b-rdo --mixed-refs ifeq (,$(VIDS)) fprofiled: @echo 'usage: make fprofiled VIDS="infile1 infile2 ..."' @echo 'where infiles are anything that x264 understands,' @echo 'i.e. YUV with resolution in the filename, or avisynth.' else fprofiled: make clean mv config.mak config.mak2 sed -e 's/CFLAGS.*/& -fprofile-generate/; s/LDFLAGS.*/& -fprofile-generate/' config.mak2 > config.mak make x264$(EXE) $(foreach V, $(VIDS), $(foreach I, 0 1 2, ./x264$(EXE) $(OPT$I) $(V) --progress -o $(DEVNULL) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif ) rm -f $(SRC2:%.c=%.o) sed -e 's/CFLAGS.*/& -fprofile-use/; s/LDFLAGS.*/& -fprofile-use/' config.mak2 > config.mak make rm -f $(SRC2:%.c=%.gcda) $(SRC2:%.c=%.gcno) mv config.mak2 config.mak endif clean: rm -f $(OBJS) $(OBJASM) config.h *.a x264.o matroska.o x264 x264.exe .depend TAGS rm -f checkasm checkasm.exe tools/checkasm.o rm -f tools/avc2avi tools/avc2avi.exe tools/avc2avi.o rm -rf vfw/build/cygwin/bin rm -f $(SRC2:%.c=%.gcda) $(SRC2:%.c=%.gcno) - sed -e 's/ *-fprofile-\(generate\|use\)//g' config.mak > config.mak2 && mv config.mak2 config.mak distclean: clean rm -f config.mak vfw/build/cygwin/config.mak x264.pc install: x264 install -d $(DESTDIR)$(bindir) $(DESTDIR)$(includedir) install -d $(DESTDIR)$(libdir) $(DESTDIR)$(libdir)/pkgconfig install -m 644 x264.h $(DESTDIR)$(includedir) install -m 644 libx264.a $(DESTDIR)$(libdir) install -m 644 x264.pc $(DESTDIR)$(libdir)/pkgconfig install x264 $(DESTDIR)$(bindir) ranlib $(DESTDIR)$(libdir)/libx264.a uninstall: rm -f $(DESTDIR)$(includedir)/x264.h $(DESTDIR)$(libdir)/libx264.a rm -f $(DESTDIR)$(bindir)/x264 $(DESTDIR)$(libdir)/pkgconfig/x264.pc etags: TAGS TAGS: etags $(SRCS) The config.mak as follows: prefix=/usr/local exec_prefix=${prefix} bindir=${exec_prefix}/bin libdir=${exec_prefix}/lib includedir=${prefix}/include ARCH=X86 SYS=LINUX CC=gcc CFLAGS=-Wall -I. -O4 -ffast-math -D__X264__ -DHAVE_MALLOC_H -DHAVE_MMXEXT -DHAVE_SSE2 -DARCH_X86 -DSYS_LINUX -s -fomit-frame-pointer LDFLAGS= -lm -s AS=nasm ASFLAGS=-f elf VFW=no EXE= VIS=no HAVE_GETOPT_LONG=1 DEVNULL=/dev/null CONFIGURE_ARGS= I have "make" and "make linux image", but in the uClinux-test-dist/romfs/bin the executable file is elf, not flat. So when I download the kennal to the board ,the application did not work. I had tried to modify "LDFLAGE= -W1 -elf2flt -lm -s" ,it was not useful. Pls give me some advice. Thanks!1 Reply
There is nobody to do the work about h.264 for uclinux on DE2??? If someone got some experience,pls give me some advice.Thanks!
