16 years agoX Window on NEEK
Hi I'm testing the X window system on my NEEK. I have some troubles because NEEK's main memory is a little bit small, the SD spi mode driver is too slow..., but the 'WindowMaker' and its app...
15 years agoHi,
--- Quote Start --- It would be great if you could create a "distribution" loadable with the Altera Application Loader on the NEEK. Same would contain as well the Software as the FPGA design binaries. --- Quote End --- It is a little bit difficult to store those in the Altera Application Loader of NEEK, because even the size of kernel itself is beyond the limit of 4MB. And by the shortage of memories, the application's response is not good compared with DE2-70's case. But I will up-load all to 'Altera Wiki', if I can solve the problem of pipes and GOT size. Kazu
