16 years agoX Window on NEEK
Hi I'm testing the X window system on my NEEK. I have some troubles because NEEK's main memory is a little bit small, the SD spi mode driver is too slow..., but the 'WindowMaker' and its app...
15 years ago --- Quote Start --- ... extract and copy it to your SD. To run it, you need a NEEK and Linux MMU version(of course:D). --- Quote End --- It would be great if you could create a "distribution" loadable with the Altera Application Loader on the NEEK. Same would contain as well the Software as the FPGA design binaries. Thanks, -Michael
