Writing via the Avalon master interface in assembly
What is required when writing to the Avalon master interface instantiated with the Nios, specifically with assembly?
I understand that in C, use can use the following macros to read/write to a specific register. IORD() IOWR() How exactly is this done in assembly? Thanks.4 Replies
Those C macros are simply wrappers to provide access to the IO instructions. See the stwio and ldwio descriptions in the instruction set reference.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/nios2/n2cpu_nii51017.pdf - Altera_Forum
--- Quote Start --- Those C macros are simply wrappers to provide access to the IO instructions. See the stwio and ldwio descriptions in the instruction set reference. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/nios2/n2cpu_nii51017.pdf --- Quote End --- I see. So if my understanding is correct, I will simply want to read and write to the address given to the Avalon master interface in Qsys using the common load/store operations? In doing so, I can initiate Avalon reads and writes? Thanks. - Altera_Forum
I have determined that my Avalon bridge is located at base address 0x2000. In this case, If I load a word (lets say 0xFFFFAAAA) to address 0x2000, I should expect an Avalon write to address 0, with the data 0xFFFFAAAA. If I load 0xAAAAFFFF to 0x2004, the Avalon master will perform a write to address 1, with the data 0xAAAAFFFF.
Does this sound correct? - Altera_Forum
Yes it sounds correct. The value you see on your component 'address' inputs will depend on the width of your component Avalon-MM Slave. For a common 32-bit wide slave, you would see a single write at address '1'. For a 8-bit slave, you would see four writes at addresses 4,5,6,7. For a 64-bit wide slave, you would see a write at address 0 with appropriate byteenables set to indicate what bytes are being written.
