12 years agowriting vhdl code in nios ii processor
Hello everyone. I am currently doing a project on cyclone iii fpga starter kit. In my project I made a counter that counts calue from 0 to 10. I want to first write these values in ssram by pressing ...
12 years agoHi mmTsuchi,
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; --use ieee.std_logic_arith.all; use ieee.numeric_std.all; use IEEE.math_real.all; entity countervhdl is generic ( DATA_WIDTH : natural := 2; ADDR_WIDTH : natural := 5 ); port( clk : in std_logic; --raddr : in natural range 0 to 2**ADDR_WIDTH - 1; waddr : in natural range 0 to 2**ADDR_WIDTH - 1; --data : in std_logic_vector((DATA_WIDTH-1) downto 0); re : in std_logic := '1'; we : in std_logic := '1'; reset : in std_logic; q : out std_logic_vector(3 downto 0)); end countervhdl; architecture counting of countervhdl is signal prescalar: integer range 0 to 50000000:=0; signal pre: integer range 0 to 9; signal count:integer range 0 to 9; --signal --subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0); type memory_t is array(2**ADDR_WIDTH-1 downto 0) of integer range 0 to 9; -- Declare the RAM signal. signal ram : memory_t; -- Register to hold the address --signal addr_reg : natural range 0 to 2**ADDR_WIDTH-1; begin process(clk,reset,pre) --variable addr:integer range 0 to 2**ADDR_WIDTH-1; variable ten:integer:=10; begin if (clk = '1' and clk'event) then if (prescalar<50000000) then prescalar<=prescalar+1; else prescalar<=0; end if; if (prescalar=0) then --for addr in 0 to 9 loop if (reset='1') then if(we = '0') then if pre<10 then pre<=pre +1 ; --elsif pre>10 then -- pre<=0; end if; ram(waddr) <= pre; --address<=addr; end if; if re='0' then count<=ram(waddr); q<=std_logic_vector(to_unsigned(count,4));--ram(addr); end if; end if; end if; end if; end process; end counting; This is my code and i want to apply this in nios system made from qsys.I used sysid,nios processor, tristate bus, ext ssram clk, onchip memory jtag_uaert,pios for led and keys. Now my problem is how to connect these read, write, output from counter in the nios processor file that is generated from qsys. In the tutorials it says i can use only eclipse ide for this counter but anyhow i want to use vhdl code. ANd I get error when i generate vhdl file in qsys but it works with verilog. Please help me. Thanks
