16 years agoWriting SDRAM HELP !!!!!!!!
Hi, I wrote a function in C to W SDRAM memory : void write_sdram() { int *buffer = (int *) 0x00800000; // SDRAM addr base buffer[0]=0xaaaa; buffer...
16 years agoI'm sure all it's correct (SOPC builder, and monitor program are configure with SRAM) but running the program some code (maybe program code is on SDRAM) and when I execute the write sdram function it writes a zone with code causing the program stops.....
