21 years agoWrite/Read file to Compact Flash
Hello: I am a software newb trying to get my hands on a program that writes and reads a file to and from the compact flash on a Cyclone board using Nios II IDE. I have gotten the the hardware ...
20 years agoI could suggest the best solution to your problem is "Work on Linux, and build nios2 uClinux". There is nothing to fear about Linux. I had been a DOS/WIndows user long a ago. But Linux is very easy to use and understand. You can learn so much from GNU/Linux, those are close to what we study in school.
Try add a PC to run Linux. Try http://www.ubuntulinux.org/ (http://www.ubuntulinux.org/) or others. You can develop hardware using quartus and nios2 on Windows. Then develop software on Linux. Follow this link to build tools/kernel/apps on Linux. http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
