21 years agoWrite/Read file to Compact Flash
Hello: I am a software newb trying to get my hands on a program that writes and reads a file to and from the compact flash on a Cyclone board using Nios II IDE. I have gotten the the hardware ...
20 years ago --- Quote Start --- originally posted by zcao@Aug 30 2005, 03:31 PM hello:
i am a software newb trying to get my hands on a program that writes and reads a file to and from the compact flash on a cyclone board using nios ii ide. i have gotten the the hardware part and the software part to run for the "compact flash monitor/debug demonstration program" under the ip section of this website. in a readme file there is description how there is additional support for the compact flash in the ecos release for NIOS II 5.0, and Micrium MicroC/FS file system.[/b] I am unfamiliar with ecos or micrium, and I assume they are operating systems? Could someone explain what they are, and what I need to execute to get them working for my board? JC <div align='right'><{post_snapback}> (index.php?act=findpost&pid=9424) --- Quote End --- [/b] --- Quote End --- Hello, I am at the same problem. If you have found out a solution, could you tell me something? I will do the same for you, JP
