21 years agoWrite own simple driver
Hi all !
To answer all questions about writting a driver in uClinux, I create this topic to collect all solutions. Please share all ! If your device type is: [uCLinux USB interface]<--------------USB cable ----------->[your device here] And you want to write a driver for it. First, There is a struct usb_driver in the kernel//location: kernel-2.6.x/include/linux/usb.h
struct usb_driver {
struct module *owner;
const char *name;
int (*probe) (struct usb_interface *intf,
const struct usb_device_id *id);
void (*disconnect) (struct usb_interface *intf);
int (*ioctl) (struct usb_interface *intf, unsigned int code, void *buf);
int (*suspend) (struct usb_interface *intf, u32 state);
int (*resume) (struct usb_interface *intf);
const struct usb_device_id *id_table;
struct device_driver driver;
}; In your driver application, you declare: static struct usb_driver myMotor_driver = {
.owner = THIS_MODULE,
.name = "usbmotor",
.probe = motor_probe,
.disconnect = motor_disconnect,
.id_table = id_table,
//The id_table variable is defined as:
static struct usb_device_id id_table = {
{ USB_DEVICE(VENDOR_ID, PRODUCT_ID) },
MODULE_DEVICE_TABLE (usb, id_table); When the driver module is loaded, this motor_driver structure must be registered with the USB core. This is accomplished with a single call to the usb_register() function: retval = usb_register(&motor_driver);
if (retval)
err("usb_register failed. "
"Error number %d", retval); Likewise, when the driver is unloaded from the system, it must unregister itself from the USB core: usb_deregister(&motor_driver); All processing is in motor_probe() function ( using usb_control_msg() kernel function ) ... /*-------------------------------------------------------------------------------------------------------------------------*/ but if your device is standalone ( ie: connected via some pins on the altera board ), how can you do ? //location: kernel-2.6.x/include/linux/device.h
struct device_driver {
char * name;
struct bus_type * bus;
struct semaphore unload_sem;
struct kobject kobj;
struct list_head devices;
struct module * owner;
int (*probe) (struct device * dev);
int (*remove) (struct device * dev);
void (*shutdown) (struct device * dev);
int (*suspend) (struct device * dev, u32 state, u32 level);
int (*resume) (struct device * dev, u32 level);
}; what steps or what functions to : - Delcare my device ( Address of device, port ... ) - Register it - Processing data or control - Deregister ... Thank you very much ! OneNet1 Reply
Good start. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
