adamS
7 years agowrite continuous data to sdram on DE0 nano board
Hi, I want to write data to sdram via nios2, then read data out and connect to LEDs to see if the data is correct. Below is my code and results. In the code I add printf("isr\n") to make sure int...
FawazJ_Altera
7 years agoI think the 0 in the middle should be a pointer to the edge capture pointer alt_irq_register (KEY_IRQ, 0, KEY_ISR);
I have tried the enhanced Interrupt before, you need to modify the system.h file, Nios ii section, you will find:
ALT_LEGACY_INTERRUPT_API_PRESENT
change it to:
ALT_ENHANCED_INTERRUPT_API_PRESENT
Then, dont re-build or update the BSP, since it will change it back to legacy mode.
This might be something like this:
#include "sys/alt_irq.h"
#include "system.h"
/* Declare a global variable to hold the edge capture value. */
volatile int edge_capture;
/* Initialize the button_pio. */
static void init_button_pio(){
/* Recast the edge_capture pointer to match the
alt_irq_register() function prototype. */
void* edge_capture_ptr = (void*) &edge_capture;
/* Enable all 4 button interrupts. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0);
/* Register the ISR. */
#ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
alt_ic_isr_register(BUTTON_PIO_IRQ_INTERRUPT_CONTROLLER_ID,
BUTTON_PIO_IRQ,
handle_button_interrupts,
edge_capture_ptr, 0x0);
#else
alt_irq_register( BUTTON_PIO_IRQ, edge_capture_ptr,
handle_button_interrupts );
#endif
- adamS7 years ago
Hi FJumaah,
Thanks for the reply!
Now I modify my code to use alt_ic_isr_register(...) function,
But unfortunately, the code is still stuck at the 65th press of the key😞
whether alt_ic_isr_register or alt_irq_register the results are the same.
#include <stdio.h> #include <unistd.h> #include "system.h" #include "alt_types.h" #include "io.h" #include "altera_avalon_pio_regs.h" #include "sys/alt_irq.h" int bKeyPressed = 0; int cnt = 1; alt_u16 incre = 0; alt_u16 data; volatile int edge_capture; void KEY_ISR(void* context){ bKeyPressed = 1; // clear interrupt flag IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_BASE,0); printf("isr\n"); } static void init_button_pio(){ void* edge_capture_ptr = (void*) &edge_capture; // enable interrupt, 2-keybutton IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_BASE,0x03); // clear capture flag IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_BASE,0); #ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT alt_ic_isr_register( KEY_IRQ_INTERRUPT_CONTROLLER_ID, KEY_IRQ, KEY_ISR, edge_capture_ptr, 0x0); printf("ENHANCED mode\n"); #else alt_irq_register (KEY_IRQ, edge_capture_ptr, KEY_ISR); printf("LEGACY mode\n"); #endif } int main() { init_button_pio(); IOWR(LED_BASE, 0, (alt_u8)0); while(1) { if(bKeyPressed) { bKeyPressed = 0; *((alt_u8*)NEW_SDRAM_CONTROLLER_0_BASE + incre) = cnt; data = *((alt_u8*)NEW_SDRAM_CONTROLLER_0_BASE + incre); printf("cnt = %d, ", cnt); printf("incre = %d, ", incre); printf("data=%x\n", data); IOWR(LED_BASE, 0, (alt_u8)data); cnt ++; incre += 1; } } printf("b\n"); return 0; }
