15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoIs the altera_reserved_clk associated with the jtag clk.Because I didnt design it while building the system with SOPC builder.I use only one clk at 50 Mhz.
But I dont know what is this other clk for? I am in the process of reading all the documentation for timing. And it actually is not affecting my design I could successfully download the design and run the code in my hardware. Thanks Again
