20 years agoWorking with Nios II and SDK
I make a new design and are going to use legacy SDK in conjuction with a Cyclone II (2C20Q240). The main reason is to use Plugs instead of LWIP and RTOS. I want to flash my executable Nios code. But there seems no tool available from altera. I tried elf2flash, but it doesn''t work. Has anybody an idea how it can be done? Thanks2 Replies
Hi Minu,
> I want to flash my executable Nios code. But there seems no tool available > from altera. Use nios2-flash-programmer. > I tried elf2flash, but it doesn''t work. Please be more specific. > Has anybody an idea how it can be done? Yes, elf2flash and nios2-flash-programmer. You should review the documentation. Regards, --Scott - Altera_Forum
Hi Scott,
after posting my message I grubbed more in the altera documentation. First it seemed I do not have success. I could not download the .flash-files. I took the USB-Blaster instead of the ByteBlasterMV. After that I could download the .flash-files. I made some tests with my own Quartus- and Nios-Projects and it worked! I had to spend a couple days running this stuff on Nios SDK Shell. Because of using Plugs I inted to use Legacy SDK instead of IDE Nios II. I am making a desing with Cyclon II 2c20Q240 FPGA (it's a new one). Now I have to wait for the Quartus version 5.1 service pack 1. I hope I will be able using the Lecacy SDK with this new versions. Regards Armin
