20 years ago
Working ISR example
Hello all,
I was developing some new hardware and had problems debugging my own ISR.
I got the code below from Slacker( modified slightly), and it helped me quickly zoom into my new hardware problem, spurious interrupt. I run the code and hardware through Modelsim 6.0c and it works fine. For a new piece of HW, just change base address and make your own interrupt source, mine is a fifo read that causes an underflow ( and an interrupt).
I did see a problem with my component when I accidentally built my module with dynamic alignment instead of native. Of course I got incorrect reads( my peripheral is only 8 bits), but worse, my interrupt would be set and my isr would not work. Not sure why, but native alignment is correct for me anyway.
Hope this is useful for someone.
-Baycool
/* Includes */
# include "io.h"# include "system.h"# include "sys/alt_irq.h"# include <stdio.h># include <stdlib.h># include "alt_types.h"
const unsigned int CMD_AVALON_BASE = (unsigned int) 0x00100800;
unsigned int check_fifo;
/* Assumes existence of SOPC component*/
/* The ISR for the irqgen component. */
static void handle_irqgen_isr(void* context, alt_u32 id)
/* Extract the "count". */
int* count_ptr = (int*) context;
/* Set the count variable. */
*count_ptr = 1;
/* Clear the IRQ. */
IOWR(CMD_AVALON_BASE, 20, 1);
/* "Initializes" the irqgen component.
* - Registers and ISR
static void init_irqgen(int* count)
/* Register the ISR. */
alt_irq_register( 1, count, handle_irqgen_isr );
/* The main loop. Capture Interrupt */
int main(void)
printf("Begin Cmd Avalon Test!\n");
/* A count variable which tracks if an interrupt has occured. */
int count = 0;
/* Initialize the irqgen component. */
init_irqgen( &count );
/* Cause Interrupt */
check_fifo = IORD(CMD_AVALON_BASE,0x0);
printf("Fifo is : 0x%X \n", check_fifo);
/* main loop */
while( 1 )
if( count == 1 )
printf(" Got interrupt, You lucky dog !! \n");
count = 0;
