14 years agoWISHBONE AVALON BRIDGE - migration problem ?
Hello, in former times I used Quartus v9.1 and NIOSII v.9.1 with an Cyclone II FPGA. Actual I use Quartus v10.1 and NIOSII v.10.1 with an Cyclone IV FPGA. Since I changed both (devleopment...
14 years agoHi BadOmen,
thank you for your reply. I try to combine the chip select with the read and write signal (OR) and it works so far. :D In an other case, i use the wishbone-avalon bridge to communicate with an Ethercat modul (Hilscher COMX). In this application, it does not work. :( I have tried to look on the handshake signals, but i have seen no activity on this signals. Can there be at this point a further problem? Thank you
