15 years agoWill Nios II work with 16-bit SRAM?
I have been trying to get an external SRAM chip to work with Nios II for over two weeks with no success. I have tested the SRAM outside of SOPC Builder with a simple VHDL routine that writes to each address then reads back the SRAM data. I used SignalTap to verify that all address and data lines are working.
I also instantiated the SRAM as a custom memory component in SOPC Builder - first with only a JTAG Master and JTAG UART, and then with a simple Nios II system. In both case I can access the SRAM component with System Console and it seems to work fine. However, in the Nios II system, I have to stop the processor to run System Console. Is this normal? My BIG problem is that I cannot get Nios II to work with the external SRAM component. Specifically, downloading the ELF file fails. I am now wondering if it is because the SRAM has a 16-bit data bus. Do I need to design an HDL component to adapt the 32-bit Nios II data bus to the SRAM 16-bit data bus, or does SOPC Builder/Avalon/Nios II do that for me? Daixiwen, thepancake, I have read a lot of your posts. From what I've seen you guys must know how to instantiate a simple 16-bit external SRAM component. Can you or someone else please help me? Many thanks in advance, fheineman
