15 years agoWill Nios II work with 16-bit SRAM?
I have been trying to get an external SRAM chip to work with Nios II for over two weeks with no success. I have tested the SRAM outside of SOPC Builder with a simple VHDL routine that writes to each...
15 years agoGreat news! Thanks Cris72 for you quick reply.
Originally I set up the custom SRAM component with a 16-bit data bus, but it doesn't work. Do you have any suggestions why I can access the custom memory component with System Console but not with Nios II? (Actually my problem is that I cannot download the ELF file, and I am assuming that it is because Nios II is not working with my custom SRAM. Perhaps this is not really the case.) I see a lot of folks on the forum having trouble downloading the ELF file through Eclipse.
