20 years agoWifi on uCLinux
Hi everybody, Does anybody knows if it is possible to have WiFI working on uCLinux for NIOS when using a PCI Wifi card connected to the Altera PCI host Bridge. What options should be enabled du...
20 years ago --- Quote Start --- originally posted by mabcom+oct 6 2006, 01:41 am--><div class='quotetop'>quote (mabcom @ oct 6 2006, 01:41 am)</div>
--- quote start ---
hi bigboss25,
with pci all generic 802.11b cards will work.
the best way is to implement the atmel 76c50x-chip.
in the kernel config you just have to enable drivers->network->wireless lan and then the hardwaredriver....
bye
marco
<!--quotebegin-bigboss25@Oct 5 2006, 09:49 AM hi everybody,
does anybody knows if it is possible to have wifi working on uclinux for nios when using a pci wifi card connected to the altera pci host bridge. what options should be enabled during the kernel configuration ?
regards.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18564)
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18570)</div> [/b] --- Quote End --- Thx a lot Marco, but where can i find the hardware driver for uCLinux ? Is it possible to use a standard Linux driver (ie for MMU processors)? Regards.
