20 years agoWifi on uCLinux
Hi everybody, Does anybody knows if it is possible to have WiFI working on uCLinux for NIOS when using a PCI Wifi card connected to the Altera PCI host Bridge. What options should be enabled du...
20 years agoHi Bigboss25,
with PCI all generic 802.11b Cards will work. The best way is to implement the Atmel 76C50x-Chip. In the kernel config you just have to enable Drivers->Network->Wireless Lan and then the Hardwaredriver.... Bye Marco --- Quote Start --- originally posted by bigboss25@Oct 5 2006, 09:49 AM hi everybody,
does anybody knows if it is possible to have wifi working on uclinux for nios when using a pci wifi card connected to the altera pci host bridge. what options should be enabled during the kernel configuration ?
regards.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18564)
--- quote end ---
--- Quote End ---
