gyuunyuu
Contributor
5 years agoWhy would someone need to use alt-file-convert and what alternatives exist?
The alt-file-convert is still in BETA version as seen below from its output message:
alt-file-convert (BETA): General file conversion tool. In 14.1, primarily used for generating Nios II applicatio...
gyuunyuu
Contributor
5 years agoThe alt-file-convert is being used for the purpose that it was created for. However, I do find it strange that this remains in beta stage for so many years although it is not such a complex tool. The documentation for this program needs to be improved. A feature is required where the start address for different memory blocks that make up the resulting file can be specified is also required.
