13 years agoWhy Vectored Interrupt Controller IRQ -1 ?
Hello Friends i have added Vectored Interrupt Controller and generate the BSP but system.h reflect that VIC IRQ is -1 /* VIC configuration */ #define ALT_MODULE_CLASS_VIC altera_vic #def...
13 years agoMost OS relies on a few hw interrupts for scheduling tasks and performing other time critical tasks.
As I said before, I believe uC/OS only uses system timer and network interrupt. All other application interrupts are actually sw emulated by OS which calls the proper isr when the hw event occurs; so these IRQs works in polling mode, instead of using interrupts controller and the irq table. The application tasks themselves are indeed executed as part of the timer/scheduler isr Your application can override this and request 'real' interrupts to be serviced, like you did. However this will never work if the OS IRQs (thus the application task which is supposed to be interrupted) have higher priority.
