13 years agoWhy Vectored Interrupt Controller IRQ -1 ?
Hello Friends i have added Vectored Interrupt Controller and generate the BSP but system.h reflect that VIC IRQ is -1 /* VIC configuration */ #define ALT_MODULE_CLASS_VIC altera_vic #def...
13 years agoHello There,
vic start working .....without os (uc/os-ii). Still struggling with OS environment..... i add the same peace of code in OS environment....but it won't work. below is the sample code which i am using in OS environment.... what else i should add in my OS environment to start Enhance interrupt
/* MicroC/OS-II definitions */
# include "includes.h"
/* Simple Socket Server definitions */
# include "simple_socket_server.h"
/* Nichestack definitions */
# include "ipport.h"
# include "tcpport.h"
# define HIGH 1
# define LOW 0
/* A variable to hold the value of the button pio edge capture register. */
# define PktSize 640
# define PktCount 460
unsigned char ImgBuff={0};
volatile int edge_capture;
# ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
static void handle_load_interrupts(void* context)
# else
static void handle_load_interrupts(void* context, alt_u32 id)
# endif
// Cast context to edge_capture's type. It is important that this be declared volatile to avoid unwanted compiler optimization.
volatile int* edge_capture_ptr = (volatile int*) context;
// Read the edge capture register on the button PIO. Store value.
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_DATA_BASE);
// Write to the edge capture register to reset it.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_DATA_BASE, 0x1);
// Read the PIO to delay ISR exit. This is done to prevent a spurious interrupt in systems with high processor -> piolatency and fast interrupts.
/* Declare a global variable to hold the edge capture value. */
//volatile int edge_capture;
// Initialize the LOAD_DATA PIO.
static void init_load_data()
// Recast the edge_capture pointer to match the alt_irq_register() function prototype.
void* edge_capture_ptr = (void*) &edge_capture;
// Enable LOAD interrupts.
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(LOAD_DATA_BASE, 0x01);
// Reset the edge capture register.
// Register the ISR.
alt_ic_isr_register(LOAD_DATA_IRQ_INTERRUPT_CONTROLLER_ID,LOAD_DATA_IRQ,handle_load_interrupts,edge_capture_ptr, 0x0);
# else
alt_irq_register( LOAD_DATA_IRQ,edge_capture_ptr,handle_load_interrupts );
# endif
void SSSSimpleSocketServerTask()
int rc;
unsigned int LPktCount = 0,Count =0;//,mycount =0;
unsigned int DataCount = 0;
//---VECTORED INTERRUPT CONTROLLER-------------------------------------------------
printf("\n\tInitillize the Enhanced Interrupt..");
# ifdef LOAD_DATA_BASE
init_load_data();
# endif
rc = alt_ic_irq_enable(VIC_INTERRUPT_CONTROLLER_ID,LOAD_DATA_IRQ);
if(rc<0) printf("\n\tEnhance Interrupt NOT enabled, Return value = %d\n",rc);
else printf("\n\tEnhnace interrupt ENABLED, Return value = %d\n",rc);
//Should i add these highlighted portion to enable other ibterrupt also..
rc = alt_ic_irq_enable(VIC_INTERRUPT_CONTROLLER_ID,HIGH_RES_TIMER_IRQ);
if(rc<0) printf("\n\tHIGH RES TIMER not Enabled, Return value = %d\n",rc);
else printf("\n\tHIGH RES TIMER ENABLED, Return value = %d\n",rc);
rc = alt_ic_irq_enable(VIC_INTERRUPT_CONTROLLER_ID,SYS_CLK_TIMER_IRQ);
if(rc<0) printf("\n\tSYS CLOCK TIMER not Enabled, Return value = %d\n",rc);
else printf("\n\tSYS CLOCK TIMER ENABLED, Return value = %d\n",rc);
usleep(10000);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xFC);
fflush(stdin);
fflush(stdout);
LPktCount = 0;
Count = 0;
usleep(10000);
while(1)
DataCount = 0;
LPktCount = 0;
printf("\n\t# Read Data at Edge Capture-Interrupt");
//------Enable start in for serializear-------------------
Count = 0;
LPktCount = 0;
edge_capture = 0;
IOWR_ALTERA_AVALON_PIO_DATA(STRT_OUT_BASE,HIGH); //Generate Start Signal
do
if(edge_capture)
edge_capture = 0; //Clear Interrupt
IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,1); //Send High to Test Pin TEMP_OUT
IOWR_ALTERA_AVALON_PIO_DATA(DATA_BASE,ImgBuff); //Send Data to DATA Bus
Count++;
printf("\nHIGH"); //not getting High
if(Count == PktSize) //check end of packet-data
Count = 0; //Point to Start of packet data
LPktCount++; //Increment packet Count
IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,0); //Send LOW to Test Pin TEMP_OUT
printf("\nLOW"); //always getting low
}while(LPktCount != (PktCount+1));
IOWR_ALTERA_AVALON_PIO_DATA(STRT_OUT_BASE,LOW); //Generate Stop Signal
//printf("\n\t# Assert LOW");
printf("\n\t#%d\t%d\t%d",ImgBuff,ImgBuff,ImgBuff);
printf("\n\t#Send Done..!!\n");
usleep(100000);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xF0);
printf("\n\t\t\tConnection Closed ...");
} //Close Simple_SOcket_Server
