13 years agoWhy Vectored Interrupt Controller IRQ -1 ?
Hello Friends i have added Vectored Interrupt Controller and generate the BSP but system.h reflect that VIC IRQ is -1 /* VIC configuration */ #define ALT_MODULE_CLASS_VIC altera_vic #def...
13 years agoHello There,
External Interrupt controller VIC have better speed performance then internal interrupt controller but in my sample code (below) for understanding VIC, won't reflect edge_capture status on pin TEMP_OUT_BASE like if edge_capture get high it will put 1 on TEMP_OUT_BASE otherwise put 0 on TEMP_OUT_BASE. my aim is to reading 2D-array whenever edge_capture get interrupt. "IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,0x1)" *i have attached my sopcinfo for refrence.
int main()
int rc;
unsigned long int count =0;
printf("\n\tInitillize the Enhanced Interrupt..");
# ifdef LOAD_DATA_BASE
init_load_data();
# endif
rc = alt_ic_irq_enable(VIC_INTERRUPT_CONTROLLER_ID,LOAD_DATA_IRQ);
if(rc<0) printf("\n\tEnhance Interrupt NOT enabled, Return value = %d\n",rc);
else printf("\n\tEnhnace interrupt ENABLED, Return value = %d\n",rc);
/* //---Should i add these alt_ic_irq_enable for other peripheral also...........??
rc = alt_ic_irq_enable(VIC_INTERRUPT_CONTROLLER_ID,JTAG_UART_IRQ);
rc = alt_ic_irq_enable(VIC_INTERRUPT_CONTROLLER_ID,SYS_CLK_TIMER_IRQ);
IOWR_ALTERA_AVALON_PIO_DATA(STRT_OUT_BASE,HIGH); //Generate Start Signal
do
if(edge_capture)
IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,0x1); //TEMP_OUT not Visible on Oscilloscope
edge_capture = 0; //Clear Interrupt
//printf("\nHIGH"); //Visible on Console
IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,0x0);
//printf("\t\tLOW\n"); //Visible on Console
}while(1);
return 0;
Regards kaushal
