20 years agowhy the uclinux2.6.15 does not work on my board
the same source
i use ./build0207 i have compiled 2.6.15.4 with mysystem.ptf ,test on my board, that is ok so , i compiled again with 2c35.ptf , test on 2c35 dev board doesn't work normal the print info like bellow: ----------------------------------------------------------------------------------------------- Linux version 2.6.15.4 ([email protected]) (gcc version 3.4.5)# 2 PR EEMPT Tue May 23 16:25:33 CST 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 256 (order: 8, 4096 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory available: 31140k/32768k RAM, 0k/0k ROM (851k kernel code, 431k data) & Linux version 2.6.15.4 ([email protected]) (gcc version 3.4.5)# 2 PREEMPT Tue May 23 16:25:33 CST 2006 --------------------------------------------------------------------------------------------- -- again------------------------------------------------------------------------------------ uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 256 (order: 8, 4096 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory available: 31140k/32768k RAM, 0k/0k ROM (851k kernel code, 431k data) --------------------------------------------------------------------------------------------- every one ! could you help me?3 Replies
If you want to use another ptf on the kernel source tree, you need to clean up with "make .... clean" or "make ... mrproper". Then do hwselect again.
thx hippo,
i will try - Altera_Forum
follows is infomation ,pls help me , thx
------------------------------------------------------------------------------------------- Linux version 2.6.15.4 ([email protected]) (gcc version 3.4.5)# 7 PRinfo:ages_ok ( DMA per-cpu: cpu 0 hot: low 0, high 0, batch 1 used:0 EEMPT Tue May 23 01:02:00 CST 2006 cpu 0 cold: low 0, high 0, b c uClinux/Nios II> 00000002<0>00 Altera Nios II support © 2004 Microtronix Datacom Ltd.008 Normal per-cpu: empty20<0> 00afab1c<0 HighMem p Built 1 zonelists Kernel command line: 0kB (0kB HighMem)0 PID hash table entries: 64 (order: 6, 1024 bytes)inactive:554 dirty:0 writeback:0 unstable:0 free: Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) <0> ffffffff<0> 00832908<0> 0000000 0> 00000000<0> 00b0ab Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 4952k/8192k RAM, 0k/0k ROM (898k kernel code, 2246k data)e74<0> 00b0a800<0>ff<0> 0 0> 008d5f10<0> 0 Mount-cache hash table entries: 512 Mount-cache hash table entries: 512 pagetables:0 DMA free:0kB min:0kB low:0kB high:0kB active:2172kB inactive:2168kB present:8192 kB pages_scanned:4615 all_unreclaimable? no lowmem_reserve[]: 0 0 0 0 DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB page s_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 0 Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pag es_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 0 HighMem free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pa ges_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 0kB DMA32: empty Normal: empty HighMem: empty 2048 pages of RAM 0 free pages 810 reserved pages 0 pages shared 0 pages swap cached ---------------------------------------------------------------------------------------------- how to do it? Yesterday, 08:15 PM Post# 2 Nios God +1 Group: Members Posts: 677 Joined: 26-October 05 From: Taipei, Taiwan Member No.: 3,428 Hi Alex.liu, How are you? The problem seem to be rootfs, it looks quite big. Please remove old rootfs, and copy it from buildroot again. rm -rf ~/rootfs cp -a ~/buildroot/build_nios2/root ~/rootfs cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot cp ~/download/inittab etc
