16 years agowhy the "reboot" can't make the device start up?
hi all : I use the uClinux NIOSII sysntem on wiki. I created a file named "upgrade" ,and write the following commands in it : dd if=/home/ftp/zimage.bin of=/dev/mtdblock1 reboot ...
16 years agoHere is another quick point. Which reboot are you using? I noticed today that I had configured the Busybox version and also the std /bin version. If I use the busybox version (just from the command line) it does not actually reboot the kernel. If I say reboot -f I get the "Rrestarting system" message and then it hangs. If I type /bin/reboot it works as it should. Obviously I need to turn off one or the other.
