21 years agowhy the project can't be builded
hello: Now ,I found a new problem , when I debuged a project using niosII IDE , after I finished all the configuration following the document , I wanted to build the project , it was fail...
21 years agoIt's difficult to say from the information that you've posted. Can you supply the complete error message (and other output) and the command line you are using?
