21 years agowhy the project can't be builded
hello: Now ,I found a new problem , when I debuged a project using niosII IDE , after I finished all the configuration following the document , I wanted to build the project , it was fail...
21 years agoYou need to specify INSTALL_DIR when calling make. How to do this from the command line is described in the Nios II eCos documentation. If you want to do this from the IDE, then you will need to follow the steps described in the thread on this forum titled: "eCos library IDE integration?"
