12 years agowhy the NiosII program don't run in 13.1
when i use NiosII 13.1 , the program don't run when i checked the "reset the selected system" in "run config" tab.the same problem, when I programmed the sof and elf to the epcs with "NiosII flash pr...
12 years agoUnfortunately I run exactly into the same issue. Did you found a solution for that?
