19 years agowhy the 3wire-spi-master have 4pins?
// the_spi_master
.MISO_to_the_spi_master(), .MOSI_from_the_spi_master(SPI_SDIO), .SCLK_from_the_spi_master(SPI_SCLK), .SS_n_from_the_spi_master(SPI_SS), ////---------------------------------------------------- intput MISO_from_the_spi_master; output MOSI_to_the_spi_master; output SCLK_to_the_spi_master; output SS_n_to_the_spi_master; do you have catch the case ? how to resolve it ?! thx1 Reply
how to connect the net of spi-master ?
spoc u_sopc( // 1) global signals: .clk(clk_cpu), .reset_n(cpu_reset_n), // the_sdram_0 .zs_addr_from_the_sdram_0(SDRAM2_A[11:0]), .zs_ba_from_the_sdram_0(SDRAM2_BA), .zs_cas_n_from_the_sdram_0(SDRAM2_CAS_n), .zs_cke_from_the_sdram_0(SDRAM2_CLKEN), .zs_cs_n_from_the_sdram_0(SDRAM2_CS_n), .zs_dq_to_and_from_the_sdram_0(SDRAM2_D), .zs_dqm_from_the_sdram_0({SDRAM2_UDQM,SDRAM2_LDQM}), .zs_ras_n_from_the_sdram_0(SDRAM2_RAS_n), .zs_we_n_from_the_sdram_0(SDRAM2_WE_n), // the_key .in_port_to_the_key(KEY), // the_led .out_port_from_the_led(LED[2:0]), // the_spi_master .MISO_to_the_spi_master(), //----------------????? how to connect? .MOSI_from_the_spi_master(SPI_SDIO),//-------?? how to connect? .SCLK_from_the_spi_master(SPI_SCLK), .SS_n_from_the_spi_master(SPI_SS), );
