17 years ago
Why PIO does not follow addressing rules ?
I am currently designing a custom peripheral and I have some problems with the data width. My peripheral is 8-bit data width and I would like that the access to a register takes place in the same manner as if I had a 32-bit width (i.e. in one cycle). But the dynamic addressing does not work like that and completes it in 4 read/write cycles as it is specified in the Avalon Interface specifications.
And I wondered how it was going for PIO. Because, we can use different width for the data, and the read/write always happen in one cycle (checked with ModelSim). Does anyone has an idea ?
Thanks in advance.
Jérôme
    The PIO actually has a 32-bit avalon interface regardless of how many bits you specify the PIO to be. The simplest thing for you to do is to make your custom peripheral have a 32 bit data bus, even if you're not using all of it.
    Jake
    Here the code of the vhd file generated by the SOPC Builder for a PIO component of 8 bits. It appears that the data bus width is 8 and not 32.
    library altera;
    use altera.altera_europa_support_lib.all;
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_unsigned.all;
    entity led_pio is
            port (
                  -- inputs:
                     signal address : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
                     signal chipselect : IN STD_LOGIC;
                     signal clk : IN STD_LOGIC;
                     signal reset_n : IN STD_LOGIC;
                     signal write_n : IN STD_LOGIC;
                     signal writedata : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
                  -- outputs:
                     signal out_port : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
                     signal readdata : OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
    end entity led_pio;
    architecture europa of led_pio is
                    signal clk_en :  STD_LOGIC;
                    signal data_out :  STD_LOGIC_VECTOR (7 DOWNTO 0);
                    signal read_mux_out :  STD_LOGIC_VECTOR (7 DOWNTO 0);
    begin
      clk_en <= std_logic'('1');
      --s1, which is an e_avalon_slave
      read_mux_out <= A_REP(to_std_logic((((std_logic_vector'("000000000000000000000000000000") & (address)) = std_logic_vector'("00000000000000000000000000000000")))), 8) AND data_out;
      process (clk, reset_n)
      begin
        if reset_n = '0' then
          data_out <= std_logic_vector'("00000000");
        elsif clk'event and clk = '1' then
          if std_logic'(((chipselect AND NOT write_n) AND to_std_logic((((std_logic_vector'("000000000000000000000000000000") & (address)) = std_logic_vector'("00000000000000000000000000000000")))))) = '1' then
            data_out <= writedata(7 DOWNTO 0);
          end if;
        end if;
      end process;
      readdata <= read_mux_out;
      out_port <= data_out;
    end europa;
    Jérôme
    What you'd really want to look at is the ".sopcinfo" file. For the PIO you will find a subsection like this:
     <parameter name="addressAlignment">
        <type>com.altera.sopcmodel.avalon.AvalonConnectionPoint$AddressAlignment</type>
        <value>NATIVE</value>
        <derived>false</derived>
        <enabled>true</enabled>
        <visible>true</visible>
        <valid>true</valid></parameter>
    It's that "NATIVE" addressing that makes the component be treated as a 32-bit wide component. Native addressing has been deprecated. See page 3-17 of the interface specification:
    http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
    You can still use Native addressing if you'd like but it's not recommended. On the interfaces tab in the component editor, expand the little arrow that says "deprecated parameters" for your avalon slave interface. There you can select "Native Addressing".
    Jake
    Ok thanks for the explanation. But I find that it is quite strange that a "default" component provided by Altera does not follow the recommendations.
    It's pretty common now actually. SoPC builder has been evolving rapidly the last few years. The PIO is an old component. I'm sure it would be quite time consuming to do a complete rewrite of every component supported by SoPC builder every time it evolved (yet that's what I do with all my components). That's why they deprecated "NATIVE" addressing rather than obsoleting it.
    Jake
