20 years agowhy not linux auto start
I suddernly find that linux should be started only by nios2-terminal. Why? It is a big problem if it is to be a product. 1. power on 2. nothing happens about linux ( I find ethernet did no...
20 years agoI write ifconfig eth0 192.168.168.1 in rc file.
And after linux run this command, the ethernet chip will power on accoding its leds and the link between my pc to it will also "connect" However, if I don't use nios2-terminate once , things described above won't happen again.
