20 years agoWHY nios2-terminal: exiting due to ^D on remote?
When running my app in NIOS II IDE. The Console siaplay: nios2-terminal: exiting due to ^D on remote,then my app stops. But I had not type "CTRL + D". Anyone can give me some advice?3 Replies
maybe your app did this....
Are you by any chance running a memory test? If you are running from ram & test ram, you overwrite your own code/stack/heap/data segments & this will cause your console to display "^D" i.e. crash
--- Quote Start --- originally posted by [email protected]@Nov 6 2006, 12:40 PM are you by any chance running a memory test? if you are running from ram & test ram, you overwrite your own code/stack/heap/data segments & this will cause your console to display "^d" i.e. crash<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19223)
--- quote end ---
--- Quote End --- Same happens to me from time to time - I was linking it to some static/noise (I have long cable between PC and target board) If it is not a communication fluke, but rather application overwriting RAM memory - is there any way to diagnoze it in more detail? What memory area could be the problem here? I do not use heap nor any other memory allocation other than local variables inside function (stack) and global variables. How to troubleshoot this problem? Also, is there a way to reconnect to the system? Restart the console? I have noticed that after such ^D problem happens my JTAG uart messages are gone even after I reattach my debugger into the running process.
