11 years agowhy nios occupy much more M9K blocks than its on-chip memory size?
hi, everyone. i use max10 08SAE, it has 387.072 bits , 44 M9K i build a nios system, with 20480 bytes on chip memory (20480*8=163840 bits), after compile the project, the report shows the pro...
11 years agoYou can try reduce your Nios I-Cache size. Currently, it is set to 32KB?
