11 years agowhy nios occupy much more M9K blocks than its on-chip memory size?
hi, everyone. i use max10 08SAE, it has 387.072 bits , 44 M9K i build a nios system, with 20480 bytes on chip memory (20480*8=163840 bits), after compile the project, the report shows the pro...
11 years agoi figure out these questions:
1. in the digital binary system, the 5120*32bit occupy the same resourses as 9182*32bit. so in order to use the M9K more efficiently, i should change the On-Chip Ram size from 5120*32 to 4096*32. i test this method on my project, and i works. 2. the "jtag_uart_0_scfifo_r" and the "jtag_uart_0_scfifo_w" only have 512 bits, but each of them occupy 1 M9k, so i enlarge the JTAG UART fifo buffer depth from 64 to 1152, so the system gets more JTAG UART fifo buffer depth without cost more M9ks.
