16 years agoWhy nios ii program execution time, sometimes fast, sometimes slow?
We use the nios ii 7.2 multi-processor, using the chip is epc3c25-384c8, cpu clock signal for the 50mhz, using assembly language, when the implementation of the interrupt program, the program executi...
16 years agoThank you,
When xcpu into the disruption, we use the oscilloscope to see the external sram read signal line, there are signals, as if reading an external program, why read buffer will extend the program execution time? In addition, we found that interruption of proceedings, only a few programs , but the actual execution time of more than a theoretical program execution time, how to solve this problem? This is a nios own shortcomings, or do we design problem?
